cakeykev(at)gmail.com Guest
Posted: Mon May 14, 2018 8:01 am Post subject: Orientation of NAV/VOR antenna compared to COM antenna |
My aerial is inside the fuselage, keeps clean doesn’t get knocked works fine.
Kevin Challis
G ODJG
| Quote: | On 14 May 2018, at 16:40, carlp101 <cparkinson(at)cisc-uk.com> wrote:
Hi Christoph,
I've just fitted a VOR/GS antenna on the belly of my Europa Tri-Gear just aft of the hatch for the central tunnel on the underside (see attached pic). It works a treat and it's all signed-off by the LAA inspector! It's a CI 157P antenna. You can either have the V of the antenna pointing forwards or backwards.
Carl
G-URMS
http://forums.matronics.com/viewtopic.php?p=480114#480114
http://forums.matronics.com//files/antenna_fitted_812.jpg
rampil
Posted: Tue May 15, 2018 11:56 am Post subject: Re: Orientation of NAV/VOR antenna compared to COM antenna |
Just because metal fused aircraft needs external vhf antennae, does
not mean it is required for glass aircraft. It only adds drag.
AirEupora
