Matronics Email List Photo and File Share
If you wish to submit a Photo and File Share of your own, please include the following information along with your email message and files:
1) Email List or List that they are related to:
2) Your Full Name:
3) Your Email Address:
Please note that the adding of your files to the Photo and File Share Directory is a semi-manual process and will take a few days to become available. A message will be posted to the Email List(s) you indicated in #1 above with a link to the new Photo and File Share when it is available.pictures@matronics.com
| Donald Meehan | RV6A step failure - both sides | |||||||||
| Harry DeLoach | Leaving Pensacola with a load of Schrimp... | |||||||||
| Terry McMillan | Dual Battery System | |||||||||
| Dave Saylor | RV-10 Big Oil Door | |||||||||
| Edward Anderson | Brake Line Failure | |||||||||
| Paul Imhof | Miss America | |||||||||
| Rob Ray | Bigger Tires | |||||||||
| Charles F. Long | GPS Color Moving Map For Less Than $500 | |||||||||
| Pat Long | Aileron Boots | |||||||||
| Daniel Lloyd | First Flight | |||||||||
| Rob Ray | Motivational Photos | |||||||||
| Bill Reining | QB Delivery by Partain Transport | |||||||||
| Matthew M. Jurotich | Please help identify this filter | |||||||||
| Clive Whittfield | Windscreen frame misalignment | |||||||||
| Alf Olav Frog / Norway | Trimtab problems are history! | |||||||||
| John W. Cox | Hartzell Composite Prop | |||||||||
| Bobby Hargrave | Canopy Skirt | |||||||||
| Bobby Hargrave | Sticky Exhaust Valve | |||||||||
| Alf Olav Frog | Prevent Water Behind Panel | |||||||||
| Richard Dudley | Groundpower jack | |||||||||
| Michael Kosta | RV-4 panel and radio console | |||||||||
| George McNutt | Roll Bar Shims | |||||||||
| Scott Lewis | PiRep - Deluxe Fuel Caps | |||||||||
| Les Featherston | Harmon Rocket | |||||||||
| John L. Danielson | Easy way to help cowl removal | |||||||||
| Steve Irving | New Harmon Rocket 1 | |||||||||
| Edward O'Connor | Archer Wingtip Antenna in RV-8 | |||||||||
| Arthur P. Loring, Jr | RV-8 Instrument Panel Access | |||||||||
| Ed Holyoke | Archer com antenna in new style wingtip | |||||||||
| David McNeill | AMSAFE inertial belts | |||||||||
| Vic Skodzinsky | Speed fairings for fuel vents | |||||||||
| eanderson@carolina.rr.com ... | Brake Line Failure | |||||||||
| Henry Hore | Leveling RV6-A Fuselage | |||||||||
| Dave Rossiter | Dave Rossiter's F1 Rocket | |||||||||
| Rob Ray | RV4 canopy hold-open latch | |||||||||
| Mike Holland | Quickbuild Fuel Pickup Issue | |||||||||
| Jeff Deuchar | Photos of Eric Hansen's rocket with new paint sche... | |||||||||
| David McNeill | O540 specs | |||||||||
| Mani Ravee | Touch up spray kit | |||||||||
| H.Ivan Haecker | Cabin Air Supply and Oil Cooler | |||||||||
| Kelly Patterson | Tailcone baggage compartment | |||||||||
| Keith T Uhls | RV-7 with GRT EFIS and Dynon | |||||||||
| Neal George | Dimpling | |||||||||
| Bob Olds | RV-4 Canopy Latch Bars | |||||||||
| Neal George | 110v Hobbs Meter | |||||||||
| Greg Gruninger | Completed RV-8! | |||||||||
| Bob Olds | Vortex generators on RV-4 | |||||||||
| Gary Gunn | Grand Canyon | |||||||||
| Bobby Hester | Matco Parking Brake | |||||||||
| Pat Long | Vernatherm | |||||||||
| Doug Gray | Plenum - Very good example & worth a look. | |||||||||
| Tom Clark | New Photo RV8 Fastback | |||||||||
| Chuck & Dave Rowbotham | Panel - N712CR | |||||||||
| Matt Dralle | WWII Bombers at Livermore California - May 31 2004 | |||||||||
| Bob Olds | Two more of the Very Best RV's | |||||||||
| H.Ivan Haecker | The Other Two Best RVs... | |||||||||
| Rob Ray | Two Best RV's... | |||||||||
| Rob Ray | Backcountry RV4 | |||||||||
| Rob Ray | RV3 pictures... | |||||||||
| Jim Cone | Jim Cone's Canopy Installation Instructions | |||||||||
| Bob Olds | Permanent Plate-nut Drill Jig | |||||||||
| Jim Jewell | Dynon Compass Module | |||||||||
| Chalkie Stobbart | RV-List article applicable to all RV's and all Ple... | |||||||||
| Chalkie Stobbart+ | Canopy and winshield attachment with Sika adhesive... | |||||||||
| Jerry Calvert | Leather Interior | |||||||||
| Rob Ray | RV-FOUR (Editor's Note | |||||||||
| Steve Glasgow | N123SG Photos | |||||||||
| Ken Brooks | Whirlwind 151-series Propeller Installation | |||||||||
| Jim Jewell | Homemade Baffle Pass Through Fitting | |||||||||
| Barry Bruns | Wing jig | |||||||||
| Doug Weiler | RV-4 Canopy Support & Hold-Open Bracket | |||||||||
| Jerry Calvert | Oil Door | |||||||||
| Jim & Terri Truitt | Jim & Terri Truitt's RV-8A | |||||||||
| Henry Hore | Rivet-gun double off-set holder for one hand opera... | |||||||||
| Henry Hore | Corrosion Inside Fuel Tank Cap | |||||||||
| Ken Brooks | Remote Magnetometer Shelf and CPU Mount for Blue M... | |||||||||
| John McMahon | Plenum | |||||||||
| Pat Long | Cracks in Wood Prop Hub Bore | |||||||||
| Bob Olds | How to build cheap strobe/tail wingtip lights | |||||||||
| George McNutt | Simple Carb Heat Muff | |||||||||
| James R. Render | N82PR First Flight... | |||||||||
| Jim Cone | Nice Straight Edge... | |||||||||
| John Starn | Cockpit Air Vents | |||||||||
| John Starn | Rocket Wheel Pant Mod | |||||||||
| Gary Zilik | CH Products Stick Grip | |||||||||
| John Starn | Wing Tip Storage Lockers | |||||||||
| TGreen | RV-10 at Scappose | |||||||||
| Meketa | RV8 flap actuator | |||||||||
| Jerry A Wilcox | RV8 #81692 Just prior to first flight | |||||||||
| Jerry A Wilcox | RV8 Engine Instillation with Custom Exhaust System | |||||||||
| Bill Gunn | Gear Fairings Source | |||||||||
| Tom Garner | Oil cooler door | |||||||||
| Cash Copeland | First Flight RV6 N46FC | |||||||||
| Dave Pohl | Ted Gauthier's RV6 | |||||||||
| Wayne Petrus | RV8A pics | |||||||||
| Len Leggette | Newly Painted RV-8A | |||||||||
| John Huft | The entire Pagosa Springs wing of Van's Airforce. | |||||||||
| Fred Stucklen | Electronic Ignition Power | |||||||||
| John Foy | foyboy6@hot.rr.com.03.09.2003 | |||||||||
| John Harris | Bracket for Wing Wiring Conduit | |||||||||
| James E. Bean | RV-8 Cooling Cowl Flap | |||||||||
| David Aronson | Brake Fluid Reservoir RV4 | |||||||||
| Karie Daniel | 7A is home! | |||||||||
| Daniel Carley | Twin Towers | |||||||||
| Rob Ray | What RV's Were Built For... | |||||||||
| Scott Van Artsdalen | First Flight | |||||||||
| Ollie Washburn | RV Tow Bars... | |||||||||
| Fred Stucklen | Instrument Panel & Radio Stack Wiring | |||||||||
| Bob Olds | AN Hardware Chart | |||||||||
| Fred Stucklen | RV-6A IFR Inst Panel & Wiring | |||||||||
| Henry Hore | RV6-A Tip-up Canopy Stiffener | |||||||||
| Marc Drake | My Two Projects... | |||||||||
| Rob Ray | Rob Ray's "Bandit" | |||||||||
| Bob & Lucille Olds | Our new RV-4, N1191X | |||||||||
| Jaye and Scott Jackson | First Flight! | |||||||||
| Gary K. | Mini Connector Pictures | |||||||||
| Kevin | Sledge Powered Dimpler | |||||||||
| Chuck and C. David Rowboth... | RV-8A Paint - Blue Angles - N712CR | |||||||||
| Gary Crowder | Tip-up canopy release mod | |||||||||
| Terry Gannon | Mystery Part | |||||||||
| Martin Hone | RV6 - Gasco Pump in Wing Root | |||||||||
| Kevin | The Round Look... | |||||||||
| Kevin | Reno Race Photos... | |||||||||
| David Fried | C-GZDF, Taperwing 6 | |||||||||
| Kevin | Dual Tanks | |||||||||
| Bob Paulovich | Fatal RV Crash | |||||||||
| Patty Gillies | Fuel Selector Plate (labeling) | |||||||||
| Kevin | Langley, BC RV Fly-in | |||||||||
| Fabian Lefler | Compressor-Tool Bench | |||||||||
| Kevin | More Pavhawk/Mt. Hood Photos... | |||||||||
| Kevin | Mt. Hoot Rescue Effort | |||||||||
| George Kilishek | RV-8 N888GK | |||||||||
| RW | New RV-8 | |||||||||
| Kevin | AK aug 2001 | |||||||||
| Gary Crowder | Manual trim cable mount | |||||||||
| Dan Checkoway | TruTrak autopilot installation diagrams | |||||||||
| Dale Larsen | Flap position indicator | |||||||||
| 3 Rotor | Alvord desert tie-down space available | |||||||||
| Bob Cutting | O-290 | |||||||||
| Jeff Bertsch | Tbird Pictures | |||||||||
| Scott Van Artsdalen | F-18 Without A Canopy... | |||||||||
| JT Garner | Landing Light Hole | |||||||||
| John Reuterskiold | RV7 Bag-Parts Database | |||||||||
| Bob Haan | New WigWag II | |||||||||
| Alex Peterson | VM11120A Vacuum switch | |||||||||
