Matronics Email List Photo and File Share
If you wish to submit a Photo and File Share of your own, please include the following information along with your email message and files:
1) Email List or List that they are related to:
2) Your Full Name:
3) Your Email Address:
Please note that the adding of your files to the Photo and File Share Directory is a semi-manual process and will take a few days to become available. A message will be posted to the Email List(s) you indicated in #1 above with a link to the new Photo and File Share when it is available.pictures@matronics.com
| Godo Barrenechea | New Canopy for 601XL | |||||||||
| Philip Smith | Firewall Seal Design | |||||||||
| Kenneth H. Buchmann | TRIO autopilot in Ch 701 | |||||||||
| Grant Corriveau | After Another Lovely Evening Flight... | |||||||||
| John Davis | Post-crash photos, 601XL, Yuba City, CA | |||||||||
| Lynn Dingfelder | Canopy Fastening | |||||||||
| Ron Steele | Steering Linkage plate to seal firewall on 601XL Q... | |||||||||
| Randall J Hebert | Definition of Tools (Humor) | |||||||||
| Charles F. Long | Low Cost Steering Boot design for 601 | |||||||||
| Ron Ellis | Instrument Panel Access | |||||||||
| Dave Miller | Gear Bending Instructions | |||||||||
| Jeffrey L. Davidson | Zenith Gather 2007 at Winchester, Virginia | |||||||||
| Charles F. Long | GPS Color Moving Map For Less Than $500 | |||||||||
| Eric Tingey | Method for fitting the canopy on a Zenith 601 | |||||||||
| John Bolding | VOR Antenna Mounted on Fuselage... | |||||||||
| Jay Bannister | Zodiac 601XL Instrument Panel Access... | |||||||||
| Dave Thompson | Proposed Zenith 601XL Panel Layout | |||||||||
| Bill of Georgia | 601 Work Recliners | |||||||||
| Herb Heaton | Scratch Building XL Wing Spars | |||||||||
| Rick Pitcher | Dual Brakes with Parking Valve | |||||||||
| B. Abbott | Zenith's For Sale | |||||||||
| Tim Shankland | Tach filter | |||||||||
| Craig Payne | Installation of auto-pilots in Zenith 601XLs | |||||||||
| Dan Morehouse | 'water stain' corrosion on sheets | |||||||||
| Bill Naumuk | Pre-punched holes | |||||||||
| Craig Payne | Bryan Martin's steering rod baffles | |||||||||
| Craig Payne | Larry McFarland's steering rod baffles | |||||||||
| Jim Pellien | Pre-Heating the 601XL SLSA | |||||||||
| Charles F. Long | Cooling improvements on the Zenith 601HDS w/Jabiru... | |||||||||
| Bill Naumuk | Wingtip picture | |||||||||
| Richard Musser | Completed At Last | |||||||||
| Herb Heaton | X-Plane version 7 of the 601XL | |||||||||
| Wayne Beattie | Zodiacs at Sentimental Journey, Lock Haven Pa. | |||||||||
| Johann G. Johannsson | Completion of my Zenith 701 | |||||||||
| Mick Kaye | UK Savannah | |||||||||
| Charles F. Long | Suggested cooling improvements for Zenith 601 HDS ... | |||||||||
| Ron DeWees | Matco Brake Modifications | |||||||||
| Brandon Tucker | Azusa Mechanical Brakes | |||||||||
| Charles F. Long | Low Cost, Light Weight Cargo Net | |||||||||
| Charles F. Long | Low Cost, Light Weight Canopy Cover | |||||||||
| Larry McFarland | 601 tire & fork jack | |||||||||
| Norman Butcher | UK based G-DONT, aircraft and instrument panel. | |||||||||
| Larry Martin | Interior/LM-701 | |||||||||
| Jeff Small | Another Pre-Heat Idea | |||||||||
| Paul Tipton | Newly flying 701 with the help of Skyshop! | |||||||||
| Charles F. Long | Idea for an Electric Pre-Heater... | |||||||||
| Larry Martin | Purty | |||||||||
| Grant Corriveau | Photos of GOLX CH601 XL for sale | |||||||||
| Bryan Martin | First flight of N61BM | |||||||||
| Trevor Page | Simple cockpit heat box | |||||||||
| Gary Gower | High Pressure struts installed in 701 doors | |||||||||
| Larry Martin | Spring loaded steering rods on a 701 | |||||||||
| Matt Dralle | WWII Bombers at Livermore California - May 31 2004 | |||||||||
| Dave Alberti | Radiator nipple solution | |||||||||
| Ray Montagne | Zenith Zodiac 601XL Fuel Sender | |||||||||
| David Barth | rough sketch of wing nose skin bending process | |||||||||
| Larry Martin | Supertrapp Mufflers on a Subaru Engine | |||||||||
| Chris Weber | Open Cockpit Zodiac | |||||||||
| Paul Petty | Stainless steel exhaust for 601/912UL combo. | |||||||||
| Gary Gower | Ascelerator cable and panel | |||||||||
| Frank Darby | Spring gear for HD/HDS | |||||||||
| Dave Kubassek | First flight of C-FDSF | |||||||||
| Brian Unruh | 701 False Ribs | |||||||||
| Randy Stout | 601 POH in Word format | |||||||||
| Philip Polstra | Pictures from Stratus Teardown | |||||||||
| Gary Zilik | CH Products Stick Grip | |||||||||
| Brenton E. Battles | Zenith-List 601 POH Template (pdf) | |||||||||
| Chris Weber | Zodiac 601 HD Special Gullwing Doors | |||||||||
| Perry Morrison | 601HD in-cockpit landing video | |||||||||
| Neil Hulin | Flange Finder Tool | |||||||||
| Bryan Martin | CH 601XL fiberglass wing tip installation | |||||||||
| Aaron Gustafson | High speed drill | |||||||||
| Andrew Zheng | Chinese Air Force Stuff | |||||||||
| Ben Haas. | Bellows for steering rod seals | |||||||||
| Wayne Beattie | Zodiac on Trailer | |||||||||
| Benford | Boots for steering for slots | |||||||||
| Chris Weber | Gullwing Version Zodiac 601 | |||||||||
| Tim Shankland | Covers for steering slots | |||||||||
| Tim & Diane Shankland | Canopy latch | |||||||||
| Gig Giacona | Bent corner of skin on 601XL Elevator | |||||||||
| RURUNY | 701 Elevator Mistake Photo | |||||||||
| Gary Gower | Stailess Steel Firewall | |||||||||
| Gary K. | Mini Connector Pictures | |||||||||
| Grant Corriveau | Zenair Gull Wing Canopy | |||||||||
| Dave Smith | lapperon handle for Zenair 701 | |||||||||
| Michael Brook | Twin Planes for Twin Pilots | |||||||||
| Grant Corriveau | Iztok Salomon's 601 Cowl | |||||||||
| Carlos Sa | Bending Dilema | |||||||||
| Grant Corriveau | Zodiac 601HD/S Canopy Hooks | |||||||||
| Michael Brooks | Michael Brooks Zenith Stol CH 701 | |||||||||
| Cleone Markwell | CH601 modifications | |||||||||
| Mark Townsend | Broken Tie Down | |||||||||
| Dave Austin | 601 Takeoff | |||||||||
| Cleone Markwell | Canopy | |||||||||
| Bob Haan | New WigWag II | |||||||||
| Huba Bajusz | Huba Bajusz / Hungary | |||||||||
| Dave Alberti | Hose connections | |||||||||
| Don Walker | Zenith HDS | |||||||||
