Matronics Email List Photo and File Share
If you wish to submit a Photo and File Share of your own, please include the following information along with your email message and files:
1) Email List or List that they are related to:
2) Your Full Name:
3) Your Email Address:
Please note that the adding of your files to the Photo and File Share Directory is a semi-manual process and will take a few days to become available. A message will be posted to the Email List(s) you indicated in #1 above with a link to the new Photo and File Share when it is available.pictures@matronics.com
| Peter James | RV-10 Hartzell Prop Spinner Cut Diagram | |||||||||
| Harry DeLoach | Leaving Pensacola with a load of Schrimp... | |||||||||
| Terry McMillan | Dual Battery System | |||||||||
| Dave Saylor | RV-10 Big Oil Door | |||||||||
| Rob Ray | Bigger Tires | |||||||||
| Daniel Lloyd | First Flight | |||||||||
| Bill Reining | QB Delivery by Partain Transport | |||||||||
| Alf Olav Frog / Norway | Trimtab problems are history! | |||||||||
| John W. Cox | Hartzell Composite Prop | |||||||||
| Bobby Hargrave | Sticky Exhaust Valve | |||||||||
| Larry Rosen | RV-10 control stick mod | |||||||||
| Richard Dudley | Groundpower jack | |||||||||
| Scott Lewis | PiRep - Deluxe Fuel Caps | |||||||||
| David McNeill | AMSAFE inertial belts | |||||||||
| eanderson@carolina.rr.com ... | Brake Line Failure | |||||||||
| Mike Holland | Quickbuild Fuel Pickup Issue | |||||||||
| David McNeill | O540 specs | |||||||||
| Mani Ravee | Touch up spray kit | |||||||||
| Jim Jewell | RV6-A lower cowl engine air intake seal | |||||||||
| Neal George | 110v Hobbs Meter | |||||||||
| Greg Gruninger | Completed RV-8! | |||||||||
| Bob Olds | Vortex generators on RV-4 | |||||||||
| Jim Cone | Jim Cone's Canopy Installation Instructions | |||||||||
| Jim Jewell | Dynon Compass Module | |||||||||
| Jerry Calvert | Leather Interior | |||||||||
| Rob Ray | RV-FOUR (Editor's Note | |||||||||
| Steve Glasgow | N123SG Photos | |||||||||
| Henry Hore | Rivet-gun double off-set holder for one hand opera... | |||||||||
| Henry Hore | Corrosion Inside Fuel Tank Cap | |||||||||
| Ken Brooks | Remote Magnetometer Shelf and CPU Mount for Blue M... | |||||||||
| John McMahon | Plenum | |||||||||
| Pat Long | Cracks in Wood Prop Hub Bore | |||||||||
| Bob Olds | How to build cheap strobe/tail wingtip lights | |||||||||
| Dan Krueger | Canopy Water Seal | |||||||||
| George McNutt | Simple Carb Heat Muff | |||||||||
| James R. Render | N82PR First Flight... | |||||||||
| Jim Cone | Nice Straight Edge... | |||||||||
| Gary Zilik | CH Products Stick Grip | |||||||||
| John Starn | Wing Tip Storage Lockers | |||||||||
| TGreen | RV-10 at Scappose | |||||||||
| Greg Hunsicker | 4 Ship Formation | |||||||||
| John Huft | The entire Pagosa Springs wing of Van's Airforce. | |||||||||
| Fred Stucklen | Electronic Ignition Power | |||||||||
| Ollie Washburn | RV Tow Bars... | |||||||||
| Fred Stucklen | RV-6A IFR Inst Panel & Wiring | |||||||||
| Bob Paulovich | Fatal RV Crash | |||||||||
